nowikovs12 Posted October 5, 2011 Share Posted October 5, 2011 Hello, I am trying to install 3ds max 2012 and I am getting this error at the very end of the install, this is related to mental ray satelite - error 1920.service mental ray 3.6 satellite for autodesk 3ds max 9 64bit 64-bit' (mi-raysat_3dsmax9_64) failed to start verify that you have sufficent privilleges to start system services Has anyone run into this issue, and how can I fix this? I am an administrator for my computer, switched off firewall, antiviruss, tried to change the satelite TCP point from 7516 to 7515, still won't work, hope you can help, thank you Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 5, 2011 Share Posted October 5, 2011 Did you happen to see this at the AutoDesk website? Not 100% sure it is applicable but it is worth the read. http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12567786&linkID=9241177 I also found this (non-AutoDesk) about the 3ds Max error 1920. http://www.cadlore.com/cadforum/8-other-autodesk-products-/1383-error-1920-while-installing-3ds-max.html Quote Link to comment Share on other sites More sharing options...
nowikovs12 Posted October 5, 2011 Author Share Posted October 5, 2011 Hello ReMark, thank you for your help, I have manadged to install, I looked in forums, and I had to switch of the User Account Control, once I did that it worked fine, thanks again Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 5, 2011 Share Posted October 5, 2011 I'm glad to hear that you have managed to finally install your program. Thanks for the update. Quote Link to comment Share on other sites More sharing options...
