Hello
I have several DWG's I'd like to make some changes to. I've tried Autoscript (the freeware) but I can't even make it draw a circle without errors.
What I would like to do is the following:
  • select all
  • move selection from specified point to specified point
  • if possible: set -dwgunits to meter
  • purgeall
  • save as DWG 2010
  • close
Anyone who can point me in the right direction on this one? What's the easiest way? I'm using AutoCAD Civil3D 2011.
Thanks!
I think you are on the right track. Did you take a look at AutoDesk's ScriptPro?
i think this could be done with a very simple script, if you are happy to do the saveas bit yourself.
or am i being too simple?
select
all
move
0,0,0
[insert new point here]
-units
[insert preferences here]
-purge
all
y
saveas
Edited by designerstuart
forgot to purge
Like above in a script re units you can set the individual parts via a setvar without having to do all.
example (SETVAR "LUNITS" 2)
Also add "Open dwgname" to start and after saveas "dwgname close" just repeat as many times as required changing dwgname, start script in any dwg.
you can also do lisp in your script so could ask for new pt each time
open dwgname
select
all
move
0,0,0
(setq pt (getpoint))
!pt
(SETVAR "LUNITS" 2)
-purge
all
y
saveas dwgname2
close
