CiCAD Posted October 7, 2011 Posted October 7, 2011 i wasnt sure where to post this and im needing this done urgently. I have a gradient hatch that using draw order i have sent to back and also tried to send behind other objects. I have tried using HPDRAWORDER (not quite sure what it does) but used values 0,1,2,3,4. the problem is when i plot the hatch, it comes to the front and i loose any lines going through the hatch. i have also used the send to back command while inserting the gradient hatch. Nothing Works How do i plot with the gradient hatch behind other objects? Please Help!!!!! Quote
f700es Posted October 7, 2011 Posted October 7, 2011 Use the normal DRAWORDER command. This should do it. Quote
