Polyline in 3d
Is it possible to draw a polyline in 3dimensional space? I can do it on 2 flat axis but not a third. So say I am in world view and do a polyline at a right angle to axis X & Y but also I want to do it along Z axis also. Is this possible?
3dpoly command
Be sure Osnapz is set to 0 if you want to snap to objects and obtain their Z value.
Z values can also be edited in Proerties.
are you able to do arcs and radius with this? mant thanks
Not with 3dpoly; you'll need to change the UCS to get arcs on the intended plane.
