ADAM'S_APPLE Posted October 7, 2011 Posted October 7, 2011 Hello, Is there a way of copying an object or viewport from one specific position in layout/paper space to the same position on another layout tab?? Know how to do it in Photoshop via the keyboard. Is there a way of doing it in CAD?? Thanks. Adam Quote
SLW210 Posted October 10, 2011 Posted October 10, 2011 Copy with Base Point and Paste to the same base point or Copy and Paste to Original Coordinates. Quote
ammobake Posted October 10, 2011 Posted October 10, 2011 Of coarse, if you don't have a title block or anything to snap to in paperspace the easiest thing to do is simply copy the layout as many times as you want (right click tab, move or copy). -ChriS Quote
CyberAngel Posted October 10, 2011 Posted October 10, 2011 If there's some question about where the title blocks have been inserted--in other words, if I didn't personally copy the layouts, or if they're from different places--I'll draw a line in paper space (or model space if need be) from a known point to the insertion point. Then I copy/paste that line from one layout to the next using the known point. Then I can paste the object of interest to the other end of that line. Clunky but sometimes necessary. Quote
BIGAL Posted October 11, 2011 Posted October 11, 2011 Got tired of consultants putting title blocks where ever so if you want it will post here, I have a move title block to 0,0 all layouts so makes copy layout then work. Quote
SLW210 Posted October 11, 2011 Posted October 11, 2011 I am the only one not seeing a mention of titleblocks in the original question? Quote
ADAM'S_APPLE Posted October 11, 2011 Author Posted October 11, 2011 lol I made no mention of title blocks specifically but by 'objects' (that term is inclusive of lines/objects that make up 'title blocks' in layouts) I mean moving anything visible in layout to the same position in another tab! Without sounding too ignorant..So how does one copy with base point and paste to the same location using co-ordinates? I mean how do you type in the exact co-ordinates when copying something? I know how to copy with base point and paste (just in case you think I'm very ignorant). (@ammobake - That was the method I was employing before!) Quote
Organic Posted October 11, 2011 Posted October 11, 2011 lol I made no mention of title blocks specifically but by 'objects' (that term is inclusive of lines/objects that make up 'title blocks' in layouts) I mean moving anything visible in layout to the same position in another tab! Without sounding too ignorant..So how does one copy with base point and paste to the same location using co-ordinates? I mean how do you type in the exact co-ordinates when copying something? I know how to copy with base point and paste (just in case you think I'm very ignorant). (@ammobake - That was the method I was employing before!) Edit -> Copy Edit -> Paste to original coordinates Edit: not sure if will do what you want after rereading the question Quote
rkmcswain Posted October 11, 2011 Posted October 11, 2011 Is there a way of copying an object or viewport from one specific position in layout/paper space to the same position on another layout tab?? In addition to the other answers' date=' ToolPac has a Layout Insert tool - which will insert the same block or image on chosen layouts, and/or allow you to copy a selection set to multiple layouts. Quote
