Civil 3D Tin Surface into Inventor
I would like to add the surface of the natural ground surrounding an building into Inventor to use as an part. My natural ground surface is an Tin Surface in Civil 3D (2011) and I'm working in Inventor 2012. Is it possible to somehow convert the TIN surface to a an file format that could be used in Inventor?
Thank you mr Mather. I will report back.
Regards
Regards
  • 5 months later...
I have opened TIN surface data from AutoCAD in Inventor before.
Save as file type dwg.
In Inventor File Open and click on Options and set on Import and settings in wizard as shown in the first problem here http://au.autodesk.com/?nd=class&session_id=3056
I have the same question, but the solution given doesnt work anymore.
(This class is not valid or is no longer active)
Maybe somebody can give me this info again.
thx
