I am a very infrequent user of CAD and still do things like I used to do back in the '90s. :(
I draw in Model space at full scale--except, and this is why I am posting this question, when I have a small detail I want to be visible.
Can I draw a detail in Model space that is a different scale than the main drawing, or do I have to make it 'larger' by using Paper space and a viewport. Like maybe a block or some procedure I am unaware of.
If there is a tutorial which describes the proper way to do this, which you are aware of, please direct me to it.
Don't know if it's the "proper way" to do it but what I do to expand an area is put a circle around the area in question, highlight a larger area around it then copy and paste to where I want the enlargement to appear in the drawing, then trim around the circle. Then it's just a matter of scaling up the area to the size you want.
Which of course should be done with a circular viewport in paperspace layout - no copy needed - so if you change the one and only original the detail view also updates. No trimming required either.
At the end of the day you can do it however you like if it works for you.
The better way would be draw the detail at scale 1:1 in model space and then use a viewport in a paperspace layout to display it at a smaller scale (i.e. so it appears larger).
I vote for utilizing paper space and viewports. You should also consider the use of annotative scaling for your text and dimensions.
