atulkumarengineer Posted October 11, 2011 Posted October 11, 2011 Dear All!, I want to import the attached file to cypecad for structural analysis. It mandatary that lower left corner of drawing should be moved at (0,0,0). How to do that?? Please help. Regards, Atul shh1.dwg Quote
Tiger Posted October 11, 2011 Posted October 11, 2011 Move > Ctrl+A > Click lower left corner > 0,0,0 Done! Quote
danellis Posted October 11, 2011 Posted October 11, 2011 Save the below routine as insn.lsp then APPLOAD the file. The command is then INSN. (defun c:insn () (command "UCS" "ORIGIN" pause "BASE" "0,0,0" )) This works on the opposite principal to Tiger's suggestion, it moves your origin and basepoints to the point you select. dJE Quote
Patrick Hughes Posted October 11, 2011 Posted October 11, 2011 Save the below routine as insn.lsp then APPLOAD the file. The command is then INSN. This works on the opposite principal to Tiger's suggestion, it moves your origin and basepoints to the point you select. dJE Please don't take this personally - I'm certain your method works for you - but my personal opinion of this approach is it introduces a number of difficulties that may appear down the road. I believe it is important to maintain a consistent and reliable origin point (the WCS) within drawings. By relocating the origin to a non world 0,0,0 there is no consistency. Quote
atulkumarengineer Posted October 12, 2011 Author Posted October 12, 2011 (edited) Dear All, Tiger's approach is simple & has worked.hats off to HER. It is good practice to start drawing from origin. I agree. thanks Atul Edited October 12, 2011 by SLW210 To save a life!!!!! Quote
