Is it possible to get the Internet date and time in a drawing by means of Visual lisp?
Ferry.
That is quite odd - it appears the result from the NIST time server is different from that which is returned when I test it. :?
All is working fine for me - perhaps it returns something different based on location?
  • 2 years later...
Hello, I have a different problem.
Sometimes, the function returns an error:
"Automation Error 80020009; [iServerXMLHTTPRequest2] Error accessing [sEND] method. ErrIndex=0"
Please help.The function returns after several calls to the correct value.
From the land down under 12:36 pm 12/08/2014
Command: TEST1
01.4.18582.2.102.2014.1
  • 6 months later...
the lisp uses port number 13 to retrieve data from the server:
(setq server "http://time.nist.gov:13")
...maybe your port is closed, check it.
Thank you, Lee Mac, for sharing all your codes!
Matteo
