psych Posted October 11, 2011 Share Posted October 11, 2011 i have attached 2 files one is screen shot of 3 pipes intersecting. the other is the .ipt part file. i am trying to extrude the angled pipe to the other 2 pipes, and cannot get the circle to extrude to both surfaces. I am a rookie at this so any help would be appreciated thanks Part2.ipt Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 11, 2011 Share Posted October 11, 2011 Something like this? Also - sketch 2 is unconstrained. - you have a sick sketch - you did not need any workplanes - you could have done this all with one sketch of 3 rectangles revolved as surfaces and trimmed. Quote Link to comment Share on other sites More sharing options...
psych Posted October 11, 2011 Author Share Posted October 11, 2011 thanks JD how did you accomplish this? I am very new to this, so the workplane way is the way I know right now. I'm not sure I was clear in my post, I also wanted to flatten the angled pipe Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 11, 2011 Share Posted October 11, 2011 Are you only interested in the angle pipe, or all three? If only interested in the angled pipe I would trim (as shown in my image history tree)> Then Thicken by Thickness and add Rip. You should then be able to Flat Pattern. Quote Link to comment Share on other sites More sharing options...
psych Posted October 11, 2011 Author Share Posted October 11, 2011 Thanks again JD got it done. I didn't know you could trim the extrusions back to the surfaces. I have alot to learn. Quote Link to comment Share on other sites More sharing options...
