Enfiel3D Posted October 11, 2011 Posted October 11, 2011 Greetings! Break out view functionality in Inventor possesses one rather unpleasant feature - its boundary is rather firmly set to be thick. It creates a lot of problems for me, because in Russian drafting standard it's supposed to be thin, and I cannot leave it thick for it would create a lot of confusion. I therefore forced to manually set it to be thin (in my case 0,18 mm). It is where the problems start. Even if I set it to be 0.18 mm, after any update it gets back to 0.35 again. When I right click it and select properties, it nonetheless shows 0.18, but it takes to close the window for it to return to 0.18 width. I tried to move it to different layers, but it didn't help. It appears to be a software bug! Is it possible at all to force break out view boundary to be always of the same (thin) width? Quote
JD Mather Posted October 11, 2011 Posted October 11, 2011 Can you post a simple example (ipt and idw or dwg) so that I don't have to make one up to experiment? Quote
Enfiel3D Posted October 11, 2011 Author Posted October 11, 2011 I can, but not right now, for I am away from Inventor. But that is rather easy to make up, just create break out view on any part, even single solid block will do. Update: I guess in ANSI drafting standard break out boundaty should be the same thickness as the main line - right? Perhaps that's the reason this feature is faulty, nobody ever noticed that in the USA. Quote
rkent Posted October 11, 2011 Posted October 11, 2011 When you edit layers, break line, the line width won't stick? Or are you talking about something else altogether? Quote
Enfiel3D Posted October 16, 2011 Author Posted October 16, 2011 I am sorry for the false alarm. The problem was with the wrong setting in the Obejct Defaults. I was dead sure that break out boundary is set to "Visible narrow", and never checked. When I finally checked the setting, it turned out to be set to "Visible". When I changed it to what I need, it started to behave in a proper way. There is NO bug. Quote
