Raudel Solis Posted October 11, 2011 Posted October 11, 2011 3ds max move issues... here is the problem sometimes when i start a new project after a while when i try to move an object by grabbing it from a corner with the Object snap and dragging it to another corner it only moves in the last axis that i utilized... for example if i move the object on the Z axis, then when i try to move the object by dragging one corner to another corner i can only move it on the Z axis..? if i i grap the gizmo and move it on the X axis, then it locks and i can only move it along the X axis until i grab the gizmo and move it along the x, y or Z axis? do you understand? Quote
Raudel Solis Posted October 12, 2011 Author Posted October 12, 2011 Issue solved somehow Axis constraint got activated? im not sure if it comes active by default.. but once i deactivated the Axis constraint i could move it freely and snap to other points now. Quote
