One more request for help, because it is a lot of sand for my truck.:D
The routine will be generate a grid from a rectangle, and before the user will be prompted to set the number of columns and number of lines.
I looked for threads on the subject but what I found did not solve.
Also not resolved with the array command.
Could this be the pseudo code:
call command
set number of columns
set number of lines
draw rectangle
draw horizontal lines
draw vertical lines
Tharwat,
Excellent. That's it. However it would be preferable that the grid lines would not be in segments. For my work would be better to not have it broken. But it solves what I wanted.
Tanks.
Also excellent, as you would expect from Lee Mac
Compared to the routine previously indicated, this does not break lines.
Although in my opinion, is better than the previous routine, because saves the data as input, which is great for repeat grid. I think it would be interesting that the grid created by default stay in their own layer. But this is peanuts.
