can I install and use SolidCam like a stand alone app.?
Hi guys,
may be my question can sound to you pretty much easy answer:
Can I use and work with SolidCam without havinfg SolidWorks installed?
I'll more than a thank to you for any advice
Stefano.
yes you can BUT you need another cad application. The only thing you get if you open the program as a stand alone is the feature tree. It will run in Acad and Inventor if i remember right.
@SolidWorksEngineer
thanks for your answer
@shift1313
hi mate, when you say:
...It will run in Acad and Inventor if i remember right
do you mean that it'll be integrated in AutoCad?
I mean, I need AutoCad to draw the solid and later than I can export it to SoildCam to simulate the manufacturing...? Am i right?
I remember when i first got SolidCAM 08 i still had acad, inventor and SW on my computer. When i opened Acad to do something with a dxf i had a SolidCAM menu at the top. I never tried to machine anything from there but i believe when you open solidcam you can use the geometry in ACAD. So the feature tree is a stand alone floating window but its still running with acad.
http://solidcam.co.uk/products/CADIntegration.htm
@shift1313
Thanks, now I get you :)
