Lithium Posted October 17, 2011 Posted October 17, 2011 I had the properties window docked on the right side of my screen before I reinstalled ACAD LT 2009. Now I can't figure out how to get it back. Maybe I'm using the wrong terminology but ACAD Help was no help and Searching here did not give me the answer. There has to be a simple answer. Quote
tzframpton Posted October 17, 2011 Posted October 17, 2011 On the Properties Palette, the third icon below the "X" button that closes the palette, click there. Make sure "Allow Docking" is selected. Then, simply drag the Tool Palette to the right side of the screen until the interface docks it. Quote
Lithium Posted October 17, 2011 Author Posted October 17, 2011 Two problems... I go to A>Modify>Properties and the palette appears under the A. Allow Docking is checked. It will not drag, so I click on Anchor Right. It goes to the right side. I uncheck Auto Hide. It goes back under the A. I cannot resize the palette. Quote
danellis Posted October 17, 2011 Posted October 17, 2011 It sounds like the palette's locked. Right click on the palette's "menu bar." An option menu should appear that will allow your to unlock the palette. dJE Quote
Lithium Posted October 17, 2011 Author Posted October 17, 2011 No matter where I click no 'option menu' appears. No menu says Unlock the palette. I sort of remember there was a revision to the original release of LT 2009. Can someone tell me how to find that update revision? This Properties Palette is quite different from the one I had in the old installation. For example, this new installation does not have a title bar which says only "Properties", while the old one did. The drawing window was entirely to the left of the Properties palette. Now the Properties palette is included on the drawing window. Please help! Quote
tzframpton Posted October 17, 2011 Posted October 17, 2011 Try this: http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ffa23ce210c4a30acaf-4f67.htm And this: http://exchange.autodesk.com/autocad/enu/online-help/search#WS1a9193826455f5ff-2ade9d9118a20d4f812b35.htm Quote
Lithium Posted October 17, 2011 Author Posted October 17, 2011 Thank you StykFacE. Right-clicking on the padlock (unlocking) got the palette to 98% of what it used to be. The Title Bar (Properties) is to the right of the palette where as it used to be on the top of the palette. How about the link to the update revision for LT 2009? Quote
tzframpton Posted October 17, 2011 Posted October 17, 2011 I don't know of any "Update Revision" for LT of any version. Are you talking about simply an update, hot-fix, or service pack? Glad the links helped. Quote
Lithium Posted October 17, 2011 Author Posted October 17, 2011 Are you talking about simply an update, hot-fix, or service pack? I guess the correct terminology is service pack--fixing errors in the original release. Quote
Lithium Posted October 18, 2011 Author Posted October 18, 2011 Never mind! I dug around on the Autodesk site and found this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13271636&linkID=9240818 AutoCAD LT 2009 Update 3 Thanks for the help. Quote
Lithium Posted October 24, 2011 Author Posted October 24, 2011 Getting back to my original question about docking the Properties toolbar on the right side of my 16:9 monitor, I have discovered how to do it the way I had done it on my old setup. You have to use the CUI. Choose your workspace, then on the right Customize workspace choose Palettes | Properties. Under Appearance set Show to Yes, set Orientation to Right, set Allow Docking to Yes, set Autohide to Off. Your full, maximized drawing window should now be visible to the left of the Properties palette. Of course you may prefer a different layout, but this is how I like my workspace set up. Quote
tzframpton Posted October 24, 2011 Posted October 24, 2011 Or you can simply use the WSSAVE option to "Save a snapshot" to whatever Workpsace you want. This simply circumvents using the CUI and can be much quicker. Quote
