Lupus Rename and Right clicking
Hi This question is not strickly design orrentated.
But i used the freeware software program for changing file names when you have hundereds of drawings.
Its called Lupus Rename if you don't have you should check it out.(http://rename.lupasfreeware.org/) it save time renaming things from your photo alborns but more inportiatly it save time renameing DWG files.
There is a feature of the program where you can right click on a folder in explorer and it will open up with lupas rename. but this is not working for me. Has anyone had this problem before and how could i fix it.
