shirazbj Posted October 17, 2011 Posted October 17, 2011 Hi, I am trying to sort an array named xc which stores center corrdinate of selected circles,like this: Array.Sort(xc) After sorting, the value of xc all became 0. Don't know why? But I tried this sort method with a vb.net only code, without relation to AutoCAD,and it gives me correct result. Below is the code for AutoCAD and have a wrong result. Thanks in advance Cean Dim sb As StringBuilder = New StringBuilder Dim xc(20) As Double Dim cnt As Integer cnt = 0 ... For Each acSSObj As SelectedObject In acSSet ... Select Case (acEnt.GetRXClass.Name) Case "AcDbCircle" Dim tcircle As Circle = CType(acEnt, Circle) If (Not (tcircle) Is Nothing) Then Dim c_pt As Point3d = tcircle.Center xc(cnt) = c_pt.X yc(cnt) = c_pt.Y r(cnt) = tcircle.Diameter cnt = cnt + 1 End If Exit Select End Select ... Next cnt = cnt - 1 sb.Append(("cnt=" + cnt.ToString + carret)) sb.Append(("before" + carret)) For i = 0 To cnt sb.Append(("Point Number,X,Y,Z," + xc(i).ToString + carret)) Next i Array.Sort(xc) sb.Append(("after" + carret)) For i = 0 To cnt sb.Append(("Point Number,X,Y,Z," + xc(i).ToString + carret)) Console.WriteLine(xc(i).ToString) Next i Quote
shirazbj Posted October 17, 2011 Author Posted October 17, 2011 This is the vb.net only code. It works. But don't know why the first post for AutoCAD one does not work. Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click Dim IntArr(3) As Double IntArr(0) = 5.2 IntArr(1) = 8.3 IntArr(2) = 9.1 IntArr(3) = 2.5 Array.Sort(IntArr) For i = 0 To 3 Debug.Print(i.ToString + " " + IntArr(i).ToString) Next End Sub Quote
Jeff H Posted October 17, 2011 Posted October 17, 2011 Since you do not know the total number of circles just use a generic list and the Sort() method only knows how to sort basic data types. It does not know if you want to sort by radius, center etc..... So you can use one of the overloaded Sort methods and pass in Comparison method. You could use a lamba but this shows sorting a list of circles by the Center.X and Center.Y property and printing them out to the command line <CommandMethod("ArrayOfCircles")> _ Public Sub ArrayOfCircles() Dim doc As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Using trx As Transaction = db.TransactionManager.StartTransaction() Dim bt As BlockTable = trx.GetObject(db.BlockTableId, OpenMode.ForWrite) Dim modelBtr As BlockTableRecord = trx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead) Dim circleList As New List(Of Circle) For Each objId As ObjectId In modelBtr If objId.ObjectClass = RXClass.GetClass(GetType(Circle)) Then circleList.Add(trx.GetObject(objId, OpenMode.ForRead)) End If Next circleList.Sort(AddressOf CompareXCenter) ed.WriteMessage("{0}Sorted by X center", Environment.NewLine) For Each c As Circle In circleList ed.WriteMessage("{0}{1}", Environment.NewLine, c.Center.ToString()) Next circleList.Sort(AddressOf CompareYCenter) ed.WriteMessage("{0}Sorted by Y center", Environment.NewLine) For Each c As Circle In circleList ed.WriteMessage("{0}{1}", Environment.NewLine, c.Center.ToString()) Next trx.Commit() End Using End Sub Private Shared Function CompareXCenter(ByVal c1 As Circle, ByVal c2 As Circle) As Integer Return c1.Center.X.CompareTo(c2.Center.X) End Function Private Shared Function CompareYCenter(ByVal c1 As Circle, ByVal c2 As Circle) As Integer Return c1.Center.Y.CompareTo(c2.Center.Y) End Function Quote
shirazbj Posted October 18, 2011 Author Posted October 18, 2011 Hi Jeff, You are using a list of objects instead of my array of doubles. But sort by x center & y center seperately is exact what I want. I can now dimension all the selected circles continuesly in both directions. Thank you very much Cean Quote
Jeff H Posted October 19, 2011 Posted October 19, 2011 Also you can use LINQ http://www.theswamp.org/index.php?topic=39723.0 Quote
fixo Posted October 19, 2011 Posted October 19, 2011 You might use classic comparer as well: SortCommands.vb Imports System.Collections.Generic Imports System.Runtime.InteropServices Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.EditorInput <Assembly: CommandClass(GetType(TesterVB.SortCommands))> Namespace TesterVB Public Class SortCommands <CommandMethod("SCRC", CommandFlags.UsePickSet And CommandFlags.Redraw)> _ Public Sub SortCircles() Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim height As Double = 0.2 Dim color As Integer = 256 Dim tid As ObjectId = ObjectId.Null Dim ar As New ArrayList() Dim tr As Transaction = db.TransactionManager.StartTransaction() Using tr Dim tv As TypedValue() = New TypedValue() {New TypedValue(CInt(DxfCode.Start), "CIRCLE")} Dim flt As New SelectionFilter(tv) Dim res As PromptSelectionResult res = ed.GetSelection(flt) If res.Status <> PromptStatus.OK Then Return End If Dim sset As SelectionSet = res.Value Dim n As Integer = 0 For Each obj As SelectedObject In sset Dim dbobj As DBObject = tr.GetObject(obj.ObjectId, OpenMode.ForRead) 'or: 'Dim dbobj As DBObject = obj.ObjectId.GetObject(OpenMode.ForRead) Dim circ As Circle = TryCast(dbobj, Circle) If circ IsNot Nothing Then If n = 0 Then Dim pt As Point3d = circ.Center Dim cid As ObjectId = circ.ObjectId Dim kp As New KeyValuePair(Of ObjectId, Point3d)(cid, pt) ar.Add(kp) End If End If Next ed.WriteMessage(vbLf & "Count = " + ar.Count.ToString()) ar.Sort(New PointYComparer()) ar.Sort(New PointXYComparer()) 'sort twice to set order as for graph Dim rows As Integer = GetRowsByFuzz(ar, 0.1) Dim columns As Integer = GetColumnsByFuzz(ar, 0.1) ed.WriteMessage(String.Format(Environment.NewLine & "Rows: {0}; Columns: {1}", rows, columns)) Try Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord) Dim cnt As Integer = 0 For i As Integer = rows To 1 Step -1 For j As Integer = columns To 1 Step -1 Dim p As KeyValuePair(Of ObjectId, Point3d) = DirectCast(ar(cnt), KeyValuePair(Of ObjectId, Point3d)) Dim txt As New DBText() txt.SetDatabaseDefaults() txt.Height = 1.0 txt.HorizontalMode = TextHorizontalMode.TextCenter txt.VerticalMode = TextVerticalMode.TextVerticalMid txt.Position = p.Value txt.AlignmentPoint = txt.Position txt.TextString = (cnt + 1).ToString btr.AppendEntity(txt) tr.AddNewlyCreatedDBObject(txt, True) cnt += 1 Next Next tr.Commit() ed.WriteMessage(String.Format(Environment.NewLine & "Done")) ed.UpdateScreen() Catch ex As System.Exception ed.WriteMessage(ex.ToString) End Try End Using End Sub Public Function GetRowsByFuzz(ByVal ar As ArrayList, ByVal fuzz As Double) As Integer Dim cnt As Integer = 0 Dim p As KeyValuePair(Of ObjectId, Point3d) = DirectCast(ar(0), KeyValuePair(Of ObjectId, Point3d)) Dim match As Double = p.Value.X For Each kp As KeyValuePair(Of ObjectId, Point3d) In ar If Math.Abs(match - kp.Value.X) < fuzz Then cnt += 1 End If Next Return cnt End Function Public Function GetColumnsByFuzz(ByVal ar As ArrayList, ByVal fuzz As Double) As Integer Dim cnt As Integer = 0 Dim p As KeyValuePair(Of ObjectId, Point3d) = DirectCast(ar(0), KeyValuePair(Of ObjectId, Point3d)) Dim match As Double = p.Value.Y For Each kp As KeyValuePair(Of ObjectId, Point3d) In ar If Math.Abs(match - kp.Value.Y) < fuzz Then cnt += 1 End If Next Return cnt End Function End Class End Namespace Module1.vb Imports System.Collections.Generic Imports System.Runtime.InteropServices Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.Geometry Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.EditorInput Module Module1 Public Class PointYComparer Implements IComparer Private Function IComparer_Compare(ByVal x As Object, ByVal y As Object) As Integer Implements IComparer.Compare Dim a As KeyValuePair(Of ObjectId, Point3d) = DirectCast(x, KeyValuePair(Of ObjectId, Point3d)) Dim b As KeyValuePair(Of ObjectId, Point3d) = DirectCast(y, KeyValuePair(Of ObjectId, Point3d)) Dim result As Integer = a.Value.Y.CompareTo(b.Value.Y) Return result End Function End Class Public Class PointXYComparer Implements IComparer Private Function IComparer_Compare(ByVal x As Object, ByVal y As Object) As Integer Implements IComparer.Compare Dim a As KeyValuePair(Of ObjectId, Point3d) = DirectCast(x, KeyValuePair(Of ObjectId, Point3d)) Dim b As KeyValuePair(Of ObjectId, Point3d) = DirectCast(y, KeyValuePair(Of ObjectId, Point3d)) Dim result As Integer = a.Value.X.CompareTo(b.Value.X) Or a.Value.Y.CompareTo(b.Value.Y) Return result End Function End Class Public Class PointXComparer Implements IComparer Private Function IComparer_Compare(ByVal x As Object, ByVal y As Object) As Integer Implements IComparer.Compare Dim a As KeyValuePair(Of ObjectId, Point3d) = DirectCast(x, KeyValuePair(Of ObjectId, Point3d)) Dim b As KeyValuePair(Of ObjectId, Point3d) = DirectCast(y, KeyValuePair(Of ObjectId, Point3d)) Dim result As Integer = a.Value.X.CompareTo(b.Value.X) Return result End Function End Class Public Class PointYXComparer Implements IComparer Private Function IComparer_Compare(ByVal x As Object, ByVal y As Object) As Integer Implements IComparer.Compare Dim a As KeyValuePair(Of ObjectId, Point3d) = DirectCast(x, KeyValuePair(Of ObjectId, Point3d)) Dim b As KeyValuePair(Of ObjectId, Point3d) = DirectCast(y, KeyValuePair(Of ObjectId, Point3d)) Dim result As Integer = a.Value.Y.CompareTo(b.Value.Y) Or a.Value.X.CompareTo(b.Value.X) Return result End Function End Class End Module It should work good if your circles were positioned like a grid ~'J'~ Quote
