woodman78 Posted October 17, 2011 Posted October 17, 2011 Does anyone have a lisp that can select a number of hatches and create one hatch in its place? Quote
ReMark Posted October 17, 2011 Posted October 17, 2011 There is no "hatch merge" option in Civil 3D? Quote
blatz.boy Posted November 16, 2011 Posted November 16, 2011 There is no "hatch merge" option in Civil 3D? ReMark, are you aware of a "hatch merge" option in AutoCAD? I work in Architecture 2012 and would be very interested if such a tool exists. Thanks. Quote
jvillarreal Posted November 18, 2011 Posted November 18, 2011 Here's a start for you (woodman78 or blatz.boy) This works on non associative hatches...No arcs. It shouldn't take much to modify it to work with all hatching. To ensure different patterns aren't selected, it'll first prompt for the hatch pattern, followed by a prompt to select all hatches to merge. ;----------------------------------------------- ;; ø Remove_nth ø (Lee Mac) ;; ;; ~ Removes the nth item in a list. ;; (defun Remove_nth (i lst / j) (setq j -1) (vl-remove-if (function (lambda (x) (eq i (setq j (1+ j))))) lst)) ;----------------------------------------------- ;; massoc (Jaysen Long) ;; ;; Extracts info from list by key ;; (defun massoc (key alist / x nlist) (foreach x alist (if (eq key (car x)) (setq nlist (cons x nlist)) ) ) (reverse nlist) );defun ;----------------------------------------------- (defun c:MH ( / hentinfo ss i n entinfo ptlist pickpntlst entlist MergedHatchList) (while (/= (cdr (assoc 0 hentinfo)) "HATCH") (setq hentinfo (car (entsel "\nSelect Hatch Pattern to use:"))) (If hentinfo (setq hentinfo (entget hentinfo)) (princ "\nMissed. Try again."))) (while (not ss) (princ "Select hatch entities to merge:")(setq ss (ssget '((0 . "HATCH"))))) (setq MergedHatchList (list (cons 0 "HATCH") (cons 100 "AcDbEntity") (assoc 8 hentinfo) (cons 100 "AcDbHatch") (assoc 10 hentinfo) (assoc 210 hentinfo) (assoc 2 hentinfo) (assoc 70 hentinfo) (assoc 71 hentinfo) (cons 91 (sslength ss)) ) i -1) (repeat (sslength ss) (setq n -1 newlist nil) (setq entinfo (entget (ssname ss (setq i (1+ i))))) (setq ptlist (cdr (massoc 10 entinfo))) (setq pickpntlst (append pickpntlst (list (last ptlist)))) (repeat (cdr (assoc 93 entinfo))(setq newlist (append newlist (list (nth (setq n (1+ n)) ptlist))))) (setq entlist (append (append (mapcar '(lambda (x) (assoc x entinfo)) '(92 72 73 93)) newlist)(list (assoc 97 entinfo)))) (setq MergedHatchList (append MergedHatchlist entlist)) (entdel (ssname ss i)) ) (setq MergedHatchList (append MergedHatchList (append (mapcar '(lambda (x) (assoc x hentinfo)) '(75 76 52 41 77 78 53 43 44 45 46 79 47)) (cons (cons 98 (sslength ss)) pickpntlst)))) (entmake MergedHatchList) ) MH_MERGE_HATCH.lsp Quote
jvillarreal Posted November 21, 2011 Posted November 21, 2011 (edited) Here's another to play with..this works for any hatching..loses associativity.. (defun c:MH ( / hentinfo ss i ent# seedpt# entinfo entinfo2 ent# seedpt# seedpts MergedHatchList) (while (/= (cdr (assoc 0 hentinfo)) "HATCH") (setq hentinfo (car (entsel "\nSelect Hatch Pattern to use:"))) (If hentinfo (setq hentinfo (entget hentinfo)) (princ "\nMissed. Try again."))) (while (not ss) (princ "\nSelect hatch entities to merge:")(setq ss (ssget '((0 . "HATCH"))))) (setq MergedHatchList (list (cons 0 "HATCH") (cons 100 "AcDbEntity") (assoc 8 hentinfo) (cons 100 "AcDbHatch") (assoc 10 hentinfo) (assoc 210 hentinfo) (assoc 2 hentinfo) (assoc 70 hentinfo) (assoc 71 hentinfo) (cons 91 (sslength ss)) ) i -1 seedpt# 0 ent# 0) (repeat (sslength ss) (setq n -1 entinfo (entget (ssname ss (setq i (1+ i)))) entinfo2 (member (assoc 92 entinfo) entinfo) entinfo2 (reverse (cdr (member (assoc 75 entinfo2)(reverse entinfo2)))) ent# (+ ent# (cdr (assoc 91 entinfo))) seedpt# (+ seedpt# (cdr (assoc 98 entinfo))) seedpts (append seedpts (cdr (member (assoc 98 entinfo) entinfo))) MergedHatchList (append MergedHatchList entinfo2) ) (entdel (ssname ss i)) ) (setq MergedHatchList (subst (cons 91 ent#)(assoc 91 MergedHatchList) MergedHatchList) MergedHatchList (append MergedHatchList (append (reverse (cdr (member (assoc 98 hentinfo)(reverse (member (assoc 75 hentinfo) hentinfo))))) (cons (cons 98 seedpt#) seedpts)))) (entmake MergedHatchList) ) Edited November 21, 2011 by jvillarreal Modified code to work with region hatches Quote
jvillarreal Posted November 21, 2011 Posted November 21, 2011 This will merge selected hatches and keep associativity. Enjoy. MH_Merge Hatch.lsp Quote
hochoaivandot Posted January 19, 2012 Posted January 19, 2012 (edited) Lisp is not working in case : Hatch Pattern is hatch that is created by Select objects, And hatch entities to merge is hatchs that are created by Pick point. Edited January 23, 2012 by Tiger removed link Quote
