I have started a routine that will allow me to copy entities from an existing drawing and place them in a new drawing from a custom template. My method involves a selection set with a basepoint, using the copybase command. I use the following code to start my new drawing.
(vla-activate(vla-add(vla-get-documents(vlax-get-acad-object)) "CFP STANDARD.DWT"))
The problem is that the rest of the code, which is a simple pasteclip to 0,0, doesnt work in the new drawing. It will start a new drawing, then paste the selection set back in to the original drawing. How do I get the code to work in the NEW drawing???
I dont see anything in your post, Lee...
"this" is the link.
Not even the hyperlink?
Nope... Maybe try messaging me the link?
"this" is the link.
HA!! I couldn't see the difference in color. I am color blind so that may have contributed.. It's OK, I will live. I just will never be able to fly a commercial airliner... *sigh* :(
Maybe this will help you?
Lee, great program, but I want to be able to have the routine create a NEW drawing and paste the objects there. Does your routine do that? Am I overlooking something there?
Thanks
Cheers :)
Indeed, my program doesn't create a new drawing, but will interface with an arbitrary drawing to which it will copy the selection of objects; hence, I thought you may be able to use the same method to interface with your new drawing, copying the required objects.
Cheers :)
I cant seem to figure it out. You mention "deep clone", is this how you are able to start a routine in one drawing, and transfer info to another drawing? That is my hiccup. I can't figure out how to start a code in drawing1, and finish it in drawing2...
"Deep Cloning" refers to the CopyObjects method used by the program to copy objects between drawing databases.
I envisaged you add a new Document Object to the Documents Collection via the Add method, then using CopyObjects to copy drawing objects to the drawing database of the new Document Object.
I'll see if I can put an example together if I have time.
