Dranoweb Posted October 16, 2008 Posted October 16, 2008 Hi all, Tackling a simple way to open a whole stack of dwg's, run a macro or two on them, and close again. Possibly one at a time - eg: have a bacth file call the dwg to acad 2009, run the macro or script to call the macro, and then close the dwg and open the next to repeat the tasks. I found a way to do this in DIESEL but it works for a max of 8 drg's. I found a way to do this with a lisp code, script and batch file in unisen, but it's far too slow to be effective. At present all I need to do is click a macro once after loading a dir full of files into autocad, and click a button, the macro closes the file when done. Short of getting an auto-click program, how can I automate this so that the macro will re-run for the next dwg? Quote
rocheey Posted October 16, 2008 Posted October 16, 2008 here might be a VBA solution. This is a modul* that recursively finds all files of a given type, then calls a subroutine for each one. If you already have some code that does these certain operations, then put a call to your main routine in the "DoSomethingWithFile" routine. This is a generic module, and can be (re)used for any VBA operations, whether run in Acad, Excel, etc, and as such, has no Autocad commands in it - including opening or closing the drawing. Call the main "FindAllFiles" routine with the filetype "*.dwg", for example; and the start path , "Y\MyDwgs\Temp\", for example. The "DoSomethingWithFile" routine, unmodified, merely lists all the files it finds to the debug window. Remember that this routine is recursive - it tunnels down into all subfolders beneath the folder you pass in the "StartPath" parameter of the "FindAllFiles" main routine. ' ---- snip ------------------------------------ Option Explicit Private Const vbDot = 46 Private Const MAX_PATH As Long = 260 Private Const INVALID_HANDLE_VALUE = -1 Private Const vbBackslash = "\" Private Const ALL_FILES = "*.*" Private Type FILETIME dwLowDateTime As Long dwHighDateTime As Long End Type Private Type WIN32_FIND_DATA dwFileAttributes As Long ftCreationTime As FILETIME ftLastAccessTime As FILETIME ftLastWriteTime As FILETIME nFileSizeHigh As Long nFileSizeLow As Long dwReserved0 As Long dwReserved1 As Long cFileName As String * MAX_PATH cAlternate As String * 14 End Type Private Declare Function FindClose Lib "kernel32" _ (ByVal hFindFile As Long) As Long Private Declare Function FindFirstFile Lib "kernel32" _ Alias "FindFirstFileA" (ByVal lpFileName As String, _ lpFindFileData As WIN32_FIND_DATA) As Long Private Declare Function FindNextFile Lib "kernel32" _ Alias "FindNextFileA" (ByVal hFindFile As Long, _ lpFindFileData As WIN32_FIND_DATA) As Long Private Declare Function GetTickCount Lib "kernel32" () As Long Private Declare Function lstrlen Lib "kernel32" _ Alias "lstrlenW" (ByVal lpString As Long) As Long Private Declare Function PathMatchSpec Lib "shlwapi" _ Alias "PathMatchSpecW" (ByVal pszFileParam As Long, _ ByVal pszSpec As Long) As Long Dim sFileExt As String Dim sFileRoot As String Public Sub FindAllFiles(FileType As String, StartPath As String) ' recursively searches a passed path for files of a given type ' FileType: a wildcard string of the file extension, ie; "*.dwg" or "*.xls" sFileRoot = QualifyPath(StartPath) 'start path sFileExt = FileType 'file type of interest Call SearchForFiles(sFileRoot) End Sub Private Sub SearchForFiles(sRoot As String) Dim WFD As WIN32_FIND_DATA Dim hFile As Long hFile = FindFirstFile(sRoot & ALL_FILES, WFD) If hFile <> INVALID_HANDLE_VALUE Then Do 'if a folder, and recurse specified, call method again If (WFD.dwFileAttributes And vbDirectory) Then If Asc(WFD.cFileName) <> vbDot Then SearchForFiles sRoot & TrimNull(WFD.cFileName) & vbBackslash End If Else 'must be a file.. If MatchSpec(WFD.cFileName, sFileExt) Then DoSomethingWithFile sRoot & TrimNull(WFD.cFileName) End If 'If MatchSpec End If 'If WFD.dwFileAttributes Loop While FindNextFile(hFile, WFD) End If 'If hFile Call FindClose(hFile) End Sub Private Function QualifyPath(sPath As String) As String ' formats passed path string to be used in recursive API search If Right$(sPath, 1) <> vbBackslash Then QualifyPath = sPath & vbBackslash Else QualifyPath = sPath End If End Function Private Function TrimNull(startstr As String) As String ' trims NULL char (ascii 0) from strings returned by API calls TrimNull = Left$(startstr, lstrlen(StrPtr(startstr))) End Function Private Function MatchSpec(sFile As String, sSpec As String) As Boolean ' uses API version of the "LIKE" command MatchSpec = PathMatchSpec(StrPtr(sFile), StrPtr(sSpec)) End Function Private Sub DoSomethingWithFile(FoundFileName As String) ' use this routine to do something with each file found ' we'll do nothing but print out the filename found Dim FoundName As String: FoundName = FoundFileName Debug.Print FoundName End Sub Quote
LCE Posted October 16, 2008 Posted October 16, 2008 Hi all, Tackling a simple way to open a whole stack of dwg's, run a macro or two on them, and close again. Possibly one at a time - eg: have a bacth file call the dwg to acad 2009, run the macro or script to call the macro, and then close the dwg and open the next to repeat the tasks. I found a way to do this in DIESEL but it works for a max of 8 drg's. I found a way to do this with a lisp code, script and batch file in unisen, but it's far too slow to be effective. At present all I need to do is click a macro once after loading a dir full of files into autocad, and click a button, the macro closes the file when done. Short of getting an auto-click program, how can I automate this so that the macro will re-run for the next dwg? If you are able to use VB.net then I can provide some code that will do it for you without even opening the file. On some fairly complex scripts I'm getting performance of 100's of drawings in a few seconds. Let me know and I could provide some pointers if it is of interest. Cheers Quote
Dranoweb Posted October 16, 2008 Author Posted October 16, 2008 I am familiar with how vb dot net operates, but not how to apply it to acad 09. I may need a little more detail on how to actually implment the VBA. Quote
ZenCad1960 Posted November 3, 2008 Posted November 3, 2008 If you are able to use VB.net then I can provide some code that will do it for you without even opening the file. On some fairly complex scripts I'm getting performance of 100's of drawings in a few seconds. Let me know and I could provide some pointers if it is of interest. Cheers I am beginning to use.net and would ve very interested in the code you mention. Please post it!. Zen Quote
Dranoweb Posted November 3, 2008 Author Posted November 3, 2008 Let me know and I could provide some pointers if it is of interest. Cheers Well basically I just need a foothold on how to get VBA going in autocad, from there I can learn a little and experiment. But until I read this forum, I thought lisp and deisel were my only options. so, as simple and obvious as it may seem - what is the first step? Quote
ZenCad1960 Posted November 3, 2008 Posted November 3, 2008 Well basically I just need a foothold on how to get VBA going in autocad, from there I can learn a little and experiment. But until I read this forum, I thought lisp and deisel were my only options. so, as simple and obvious as it may seem - what is the first step? Since you haven't done VBA before I would start by looking up generral VBA Sites the offer tutorials on the basics, the you could go to some AutoCAD specific sites: The following two are just some of many but I find these two most helpful so far: http://rkmcswain.blogspot.com/ This is from on the folks here in this forum I believe. http://blog.jtbworld.com Is another site I find useful not only for AutoCAD but for other office products as well. I can post the VBA Tutorial sites I have found if you want them... Zen Quote
Dranoweb Posted November 3, 2008 Author Posted November 3, 2008 Well I am familiar with VBA from ACCESS, have had much database work in the past. TY muchly for the pointer, I shall begin my journey into the miles of reading that await me. Quote
