Maybe I should change this. I got a new plotter. IT set it up, but they know nothing about autocad. I plot on the new plotter fine. When I print to my small printer I set the different size and pen weights and all. OK, that works. The problem is when I go back into the original plotter drawing, I have to reset all my settings. Even from plot to plot in the same drawing. It doesn't seem to hold the settings from one device to the other. When I try and save the PC2 or Partial PCP file under Configuration File in the plot tool, I don't know where to save it to. Wouldn't that save the settings? THe new plotter is the default device if that helps.
Using R14, an old version. Plotter is HP T790.
Edited by gsksun4
