XREF list extraction
Hi all,
Is there a quick and painless
way to extract a list of all the
XREF's in the drawing from the
external references box?
Did a quick search earlier and got
nothing that was quite what i was after.
Thanks in advance,
Skipso
You want a list extracted to an notepad-format or just displayed in the drawing file? A Field would give you all the external references in the drawing in a list.
Either way is good, just need to be able to print it off as in order to make drawing work i need to brak it up into smaller drawings, the filesize is getting ridiculous (526MB) so if i can break it up and then "tick" off which xrefs are in which dwg, that'll help (I hope)
I'm sorry Skipso, I know it can be done with Fields, I played around with it during the summer, but I can't remember now how it was done - it could have been with a Diesel-expression... hopefully someone will come along that knows what I'm on about...
Chhers for the input tiger, at least now i know it can be done,
just have to wait and see as to how now.
Add the following code using RTEXT, diesel option
Xref's in this file are indicated as - Xref name [Filepath]
$(Xrefs,3,)
$(Images,3,Images in this file: )
The above will give you the name of the xref, and its full file location; and the full file location of any images attached to the drawing.
this is where i put my dunce hat on,
Diesel???
Run the RTEXT command, it will become self evident after that.
If not, enter RTEXT at the command line, then enter D (for Diesel), then copy the code i posted above in the box, and press ok.
ok cheers, an will this work even if the xref's are "not found" in the xref manager, i.e. listed but not where they should be?
hmm, it will only list the last saved path of the references. It doesn't show whether they are found at that path or not.
that's all I need, THANKYOU THANKYOU and er THANKYOU AGAIN!!!!
you better beleive it - bluey = lifesaver
oh dear we got a problem :cry:
  • 5 years later...
Works for me! Thnx
$(Xrefs,3,)
