CitrixGuy Posted October 24, 2011 Posted October 24, 2011 Has anyone installed AutoCAD on Xenapp, or wants to ? Quote
BIGAL Posted October 25, 2011 Posted October 25, 2011 Check out the www.autodesk.com site for info on Citrix it is possible, also AUGI had a press release a couple of months ago about Autodesk & Citrix Yes we run Citrix but not Autocad on it maybe in future. Quote
Bill Tillman Posted October 26, 2011 Posted October 26, 2011 I can only assume that is will run correctly, but I can also imagine how slow it might be. Depending on how many users are logged in to the Citrix server. I use to work as an IT Admin and we used Citrix. Once we reach about 5-6 users logged in the speed became a major issue and we ended up building new Citrix servers for the additional users. Citrix does not equal speed no matter which way you look at it. Quote
BIGAL Posted October 26, 2011 Posted October 26, 2011 We have around 1000 users around 200 in the building I am in majority have acces to Citrix. Some days weeeee hhhhaaavvvveee aaaaa ppprrrrobbbblemmmm withhhhh spppeeeddd Quote
Guest angelea Posted October 26, 2011 Posted October 26, 2011 I dont see the logic to use this software on TS. Autodesk may have some solution to your problem, but the load on the server can lead to move to regular desktops Quote
CitrixGuy Posted October 26, 2011 Author Posted October 26, 2011 We are currently running trial with a company called IMSCAD, and it seems to running really well, I wanted other people thoughts, The reason we are looking at Citrix versions, our user can now use AutoCAD on there ipad on site, which they tell me is very useful. We are using Xenapp 6 and a HP server with an Nvidia card, what spec did you guys try ? Quote
BIGAL Posted October 27, 2011 Posted October 27, 2011 To clarify Autocad standalone & networked but not on Citrix we just have it as a possible solution for some real casual users rather than tie up the network versions. Quote
