ASMI.Tools XTube/XPipe : Request for help
hi, a newbie to the group here.:)
i've downloaded and used lisp routines by ASMI particularly XTube & XPipe. i noted that ASMI ended from participating in this forum back in jan.2010.
xtube.lsp basically extrude 3d circular pipe from a line / polyline & arc. i attach the routine at the end of the message.
i only have a very basic autolisp know-how and that was more than 10 yrs ago. now i'm kind of lost with vb & vlisp and found it difficult to customize/edit xtube.lsp
i hope to get some assistance how to amend this xtube.lsp to do the following
  • extrude a 3d rectangular hollow pipe (width w, depth h, thickness t) instead of a circular pipe
i guess the main engine of the routine is the following part
[font=Courier New](setq 3dPos(list XOrd YOrd ZOrd)[/font]
[font=Courier New]             exCir(vla-addCircle actSp [/font]
[font=Courier New]                     (vlax-3d-Point startPt) [/font]
[font=Courier New]                       (/ tube:Width 2)) [/font]
[font=Courier New]             inCir(vla-addCircle actSp [/font]
[font=Courier New]                        (/ tube:Height 2)) [/font]
[font=Courier New]             ); end setq [/font]
i could not find a term in vlisp to replace -addCircle ( say -addRectangular so instead of drawing a circle the routine draws a rectangular to be extruded).
any suggestion is very much appreciated.
cheers
;;  XTUBE.LSP - Fast 3D-pipe extrude.                                   ;;
;;  Command(s) to call: XTUBE                                           ;;
;;  Select Lines, Polylines or Arcs, specify external and               ;;
;;  internal pipe diameter and press Enter. The program will            ;;
;;  extrude pipes. You can erase path lines after it.                   ;;
;;  THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD ON ANY    ;;
;;  MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS PROGRAM OR        ;;
;;  PARTS OF IT ABSOLUTELY FREE.                                        ;;
;;  THIS PROGRAM PROVIDES 'AS IS' WITH ALL FAULTS AND SPECIFICALLY      ;;
;;  DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS        ;;
;;  FOR A PARTICULAR USE.                                               ;;
;;  V1.2, 17 June, 2005, Riga, Latvia                                   ;;
;;  © Aleksandr Smirnov (ASMI)                                          ;;
;;  For AutoCAD 2000 - 2008 (isn't tested in a next versions)           ;;
;;                             [url]http://www.asmitools.com[/url]                 ;;
(defun ctube(/ 3DPOS ACTDOC ACTLAY ACTSP BASELINE
                BASESET DICOUNT DIVDID EXCIR EXENT
                EXTUBE INCIR INENT INTUBE LAYST
                OBJTYPE OLDECHO oldWidth oldHeight
                STARTPT XORD YORD ZORD DELFLAG *ERROR*)
 (vl-load-com)
 (defun *error* (msg)
   (vla-put-Lock actLay laySt)
   (setvar "CMDECHO" oldEcho)
   (vla-EndUndoMark actDoc)
   ); end of *error*
 (if(not tube:Width)(setq tube:Width 40.0))
 (if(not tube:Height)(setq tube:Height 37.0))
 (setq actDoc
   (vla-get-ActiveDocument
     (vlax-get-Acad-object))
  actLay(vla-get-ActiveLayer actDoc)
       oldWidth tube:Width
  oldHeight tube:Height
       oldEcho(getvar "CMDECHO")
  ); end setq
 (vla-StartUndoMark actDoc)
 (setvar "CMDECHO" 0)
 (if(= 0(vla-get-ActiveSpace actDoc))
   (setq actSp(vla-get-PaperSpace actDoc))
   (setq actSp(vla-get-ModelSpace actDoc))
   ); end if
 (setq laySt(vla-get-Lock actLay))
 (vla-put-Lock actLay :vlax-false)
 (setq tube:Width
   (getreal
     (strcat
       "\nSpecify external diameter <"(rtos tube:Width)">: "))
      tube:Height
   (getreal
     (strcat
       "\nSpecify internal diameter <"(rtos tube:Height)">: "))
  ); end setq
 (if(null tube:Height)(setq tube:Height oldHeight))
 (if(null tube:Width)(setq tube:Width oldWidth))
 (if(< tube:Height tube:Width)
 (princ "\n<<< Select objects to extrude and press Enter >>>")
 (if
   (setq baseSet
     (ssget '((-4 . "<OR")(0 . "*LINE")(0 . "CIRCLE")
          (0 . "ARC")(0 . "ELLIPSE")(-4 . "OR>")
          (-4 . "<NOT")(-4 . "<OR")(0 . "SPLINE")
               (0 . "MLINE")(-4 . "OR>")(-4 . "NOT>"))))
     (setq baseSet(vl-remove-if 'listp
                             (mapcar
           'cadr
           (ssnamex baseSet))))
     (foreach pathEnt baseSet
     (setq baseLine
       (vlax-ename->vla-object pathEnt)
           objType(vla-get-ObjectName baseLine)
           startPt(vlax-curve-getStartPoint baseLine)
           3dPos
       (vlax-curve-getFirstDeriv baseLine
         (vlax-curve-getParamAtPoint baseLine startPt))
          diCount(strlen
           (itoa
        (apply 'max
         (mapcar 'abs
          (mapcar 'fix startPt)))))
          divDid "1"
      ); end setq
   (repeat diCount
         (setq divDid(strcat divDid "0"))
       ); end repeat
        (setq divDid(atoi divDid))
        (if(/= 0.0(car 3dPos))
          (setq XOrd(/(car 3dPos)divDid))
          (setq XOrd (car 3dPos))
        ); end if
        (if(/= 0.0(cadr 3dPos))
          (setq YOrd(/(cadr 3dPos)divDid))
          (setq YOrd (cadr 3dPos))
        ); end if
       (if(/= 0.0(nth 2 3dPos))
          (setq ZOrd(/(nth 2 3dPos)divDid))
          (setq ZOrd (nth 2 3dPos))
        ); end if
                      (/ tube:Width 2))
                       (/ tube:Height 2))
            ); end setq
     (vla-put-Normal exCir(vlax-3D-point 3dPos))
     (vla-put-Normal inCir(vlax-3D-point 3dPos))
     (setq exEnt(vlax-vla-object->ename exCir)
           inEnt(vlax-vla-object->ename inCir)
           ); end setq
 (command "_.extrude" exEnt "" "_p" pathEnt)
 (setq exTube(entlast))
 (command "_.extrude" inEnt "" "_p" pathEnt)
 (setq inTube(entlast))
 (command "_subtract" exTube "" inTube "")
 (command "_.erase" exEnt "")
 (command "_.erase" inEnt "")
  ); end foreach
  (initget "Yes No")
     (setq delFlag
         (getkword "\nDelete extrude path(s)? [Yes/No] <No>: "))
     (if(null delFlag)(setq delFlag "No"))
     (if(= "Yes" delFlag)
          (vla-delete(vlax-ename->vla-object pathEnt))
    ); end foreach
      ); end if
      ); end progn
     ); end if
    ); end progn
   (princ "\nInternal diameter more or equal external diameter! ")
   ); end if
); end  of ctube
(princ "\n[info] http:\\\\[url="http://www.AsmiTools.com"]www.AsmiTools.com[/url] [info]")
(princ "\n[info] Type XPIPE for extrude 3D-pipes. [info]")
Edited by SLW210
added code-tags to the snippet of code
You need to read the CODE POSTING GUIDELINES. It has been done for you this time, but in the future please use them.
oops, so sorry about that. didnt aware of the rule.
cheers
