hi guys,
How do I:
1) Select a mline and explode it.
2) "setq ent" the line which was picked to explode the mline.
3) "setq pt" using vlax-curve-getclosestpointto
4) All in one click of the mouse.
Sorry guys, I'm having trouble expressing myself in english (and also in lisp) so I just enumerated.
Thank you.
(defun c:test (/ TheLine Ent Npt)
 (vl-load-com)
 (setq theLine (entsel "\nSelect Mline: "))
 (command "_explode" theLine)
 (setq Npt (vlax-curve-getClosestPointTo
      (setq Ent
      (vlax-ename->vla-object (car (nentselp (cadr TheLine))))
      (cadr TheLine)
 (vla-highlight Ent :vlax-true)
 (print Npt)
Be careful if other objects surround the MLine, it would be difficult to guarantee the correct entity will be selected using nentselp ;)
Maybe this old code will offer some ideas :)
(mapcar '(lambda ( x ) (ssadd x ss)) [color=blue][b](_Entnext el)[/b][/color])
(defun _Entnext ( e )
   (if (setq e (entnext e)) (cons e (_Entnext e)))
Very nice, it works for blocks as well, it gave me an idea for a routine i'm working on regarding block layers
Cool Beans.
Thanks Lee.
Hope you dont mind if i "borrow" your _Entnext routine for a while till i write my own version
Again, Thank you my friend
:beer:
:beer:
Its only two lines of code... go ahead :)
I appreciate the courtesy of asking before taking.
