Theja Posted October 26, 2011 Posted October 26, 2011 I am not able to convert a 2d gear to 3d gear . I have attached the 2d gear that i had created . Please help me upon that . I use Autocad student version 2012 . The gear is not getting converted into a complete solid on use of extrusion command . There are gaps in within the gear around the circle or something like that . Please help gear.dwg Quote
ReMark Posted October 26, 2011 Posted October 26, 2011 Simply switch to an isometric view and use PressPull. It will work. Quote
Theja Posted October 26, 2011 Author Posted October 26, 2011 Yea I got that . Thanks man . But now i face another problem - I type the rotate script and set the speed to 1 It rotates for about 3 - 4 times and the application hangs up . Like it stops responding . Is this a software problem or something to do with my hardware ? 2Gb Ram with 2.93 GHz Core 2 Duo processor sounds enough right ? Quote
ReMark Posted October 26, 2011 Posted October 26, 2011 My best guess at the moment is it's a hardware problem. 2GB of RAM is anemic. What do you have for a graphics card/chip? Quote
Theja Posted October 26, 2011 Author Posted October 26, 2011 NVIDIA Geforce 9400 GT ( 1 Gb) . And is there a software kind or an add-on to include gear functions in Autocad or Autocad Inventor Fusion ? I really want to explore this topic . I've seen a number of videos on youtube but none of them explain how gears work relatively . They automatically start off with readymade gears and they somehow move relatively ! I don't understand how they approached that . Could you please help me on this confusion ? Quote
ReMark Posted October 26, 2011 Posted October 26, 2011 Count me in as one of those confused types. That's a question best answered by more knowledgeable forum members than myself. Don't worry. Someone will eventually come along and educate us both. Quote
JD Mather Posted October 26, 2011 Posted October 26, 2011 And is there a software kind or an add-on to include gear functions in Autocad or Autocad Inventor Fusion ? All of this is pretty automatic in Autodesk Inventor (NOT Inventor Fusion). If you are doing mechanism motion studies (kinematics) or beyond that - Dynamic Simulation (gravity, forces, loads, contacts) you should be using Autodesk Inventor. Students can download Inventor Professional for free 3-yr license from http://www.autodesk.com/edcommunity Inventor Fusion is a different product than Inventor. Fusion is more for translation between CAD programs and quick conceptual design. Inventor Fusion is free. Autodesk Inventor is a long way from free (except for students). Quote
Theja Posted October 26, 2011 Author Posted October 26, 2011 Thanks for the help , sir . I am indeed a student , dealing with kinematics . Will try out the software right away Quote
