Critzman Posted October 16, 2008 Posted October 16, 2008 I have a question that I'm assuming might not be possible... but I'll give it a try. I have created dynamic blocks for my firm, and one thing I have added are key tags associated with those blocks (to identify equipment). The key tags have a rotation associated to them so the text can be orientated with the dwg whenever the dynamic it's self is rotated. I have a couple blocks where I array to create several consecutive entities, I array the key tags as well, but of course the parameter doesn't rotate. When I rotate the text of the original key tag, it rotates on that base point. Is there anyway to array the objects, with the key tags, but get each key tag to rotate individually? Thanks. -Brian Quote
