rock1 Posted October 27, 2011 Posted October 27, 2011 I used a door with a white hatch box to avoid trimming all my glazed entrances to the shops. If i print my drawing in greyscale mode, the boxes show up with a very light gray hatch [not an issue at all]. But now i want to print my drawing in coloured mode with all the layers showing their respective colours. When I use acad.ctb. These white filled boxes get filled with ugly gray colour. Same is the problem when I use the none.ctb. I've attached a file to check. What should I do? I make a pdf of my files to get the prints from a print shop. sample for cadtutor.dwg Quote
