How to check if a point is in a list ?
Hello .
How can I check if a point of coordinates is a member in a list of points ?
 (setq pts '((27.3814 14.1609 0.0) (24.6235 10.9329 0.0) (19.8956 13.6626 0.0) (17.6971 9.85463 0.0)))
(setq pt '(27.3814 14.1609 0.0))
(member pt pts)
Thanks in advance
Edited by Michaels
Forgot to type comman for the list of points
(defun C:test (/ pts pt)
(if (member pt pts)
 (princ "\n Point list found")
 (princ "\n Point list not found")
Thank you so much . :)
My try was the same as yours , and I do wonder why it did not work for me at the beginning !!!
Cheers :beer:
Watch out for (member) calls in lists that contain REALs. There isn't a fuzz factor so the numbers must be exact matches. A lot depends on how the numbers were attained. -David
Good point David. I guess you could roll your own...
(defun _member (item lst)
 (if (car lst)
   (if (equal (car lst) item)
     lst
     (_member item (cdr lst))
Very elegant Alan :)
A few variations:
(defun _memberwithfuzz ( expr lst fuzz )
   (vl-member-if '(lambda ( x ) (equal x expr fuzz)) lst)
(defun _memberwithfuzz ( expr lst fuzz / x )
   (while (and (setq x (car lst)) (not (equal expr x fuzz)))
       (setq lst (cdr lst))
   lst
(defun _memberwithfuzz ( expr lst fuzz / foo bar )
   (defun foo ( x ) (equal x expr fuzz))
   (defun bar ( x )
       (if (foo x) (progn (defun foo ( x ) (list x)) (list x)))
   (apply 'append (mapcar 'bar lst))
Edited by Lee Mac
;;;SearchAtom List Fuzz
(defun memberfz (s l f / r)
(foreach a l
  (and (not r)
       (equal s a f)
       (setq r T)))
 r)
-David
A few variations:
Thanks, you too.
Slight mod with definable fuzz factor...
(defun _memberFuzz (item lst fuzz)
 (if (car lst)
   (if (equal (car lst) item fuzz)
     lst
     (_member item (cdr lst) fuzz)
Thanks so much guys ,
I have lots of things to read .
Highly appreciated .
