jankhan Posted October 16, 2008 Posted October 16, 2008 Is there any .lisp file (autocad 2000-2002) - In survey data entry of boundary lines I insert circle symbol at the corners of lot boundaries. In the hard copy I want the boundary lines within the circle symbol not plotted, however on the screen when the boundary line is inquired I need to get the actual length. I do not want to trim the lines within the circle. ie all entites within the circle displayed but not plotted. Thanks Quote
lpseifert Posted October 16, 2008 Posted October 16, 2008 Make a block containing a circle with a wipeout inside. PL-CIRCLE.dwg Quote
jankhan Posted October 16, 2008 Author Posted October 16, 2008 Thanks mate, I will try it later today. Quote
VovKa Posted October 16, 2008 Posted October 16, 2008 (defun c:Test (/ *error* LayerName SS Size) (if ((lambda (n) (or (vl-position n (arx)) (and (setq n (findfile n)) (arxload n)) ) ) "acmpolygonui.arx" ) (progn (setq LayerName (getvar "CLAYER") Size 10 ) (if (setq SS (ssget (list (cons 0 "LWPOLYLINE")))) (foreach EntName (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) (foreach Coord (vl-remove-if-not (function (lambda (c) (= (car c) 10))) (entget EntName) ) (setq Coord (cdr Coord)) (entmakex (list '(0 . "MPOLYGON") '(100 . "AcDbEntity") (cons 8 LayerName) '(100 . "AcDbMPolygon") '(70 . 1) '(10 0.0 0.0 0.0) '(210 0.0 0.0 1.0) '(2 . "_SOLID") '(71 . 1) '(91 . 1) '(92 . 2) '(73 . 0) '(72 . 1) '(93 . 2) (list 10 (/ Size 2.0) 0.0 0.0) '(42 . 1.0) (list 10 (/ Size -2.0) 0.0 0.0) '(42 . 1.0) '(76 . 1) '(63 . 7) '(421 . 16777215) (cons 11 Coord) '(99 . 0) '(450 . 0) '(451 . 0) '(460 . 0.0) '(461 . 0.0) '(452 . 0) '(462 . 0.0) '(453 . 0) '(470 . "") ) ) ) ) ) ) (princ) ) ) Quote
jankhan Posted October 17, 2008 Author Posted October 17, 2008 Hi vovka, Thanks, I loaded the .lsp in autocad 2002, its not working. I have attached a pdf of the survey plan, the line were trimed, I need to insert the three symbols types with line going to the centre but not plotting. ie stops at the outer edge of symbols. Sorry I am new in using lsp. jan surveyplan.pdf Quote
VovKa Posted October 17, 2008 Posted October 17, 2008 jankhan i think you do not have the file acmpolygonui.arx, it is a part of Map I suppose. then you should act the way that lpseifert proposed - create blocks with either wipeouts or solid hatches of color 255,255,255 Quote
