I'm trying to model the bottom of a cylinder where the surface is not co-planer..... Is there a command other than rulesurf that will get me the same results? I keep getting my mesh all hosed up (like in the attached) no matter how I pick my points. (it's driving me nuts :?
anybody?
slope.pdf
sorry im not familiar with mep but if I was tyring to model that as a mesh surface i would make my slot 4 segments and my cylinder 4 secments(with lines between the end points) so you have 4 lines for an edgesurf. can you not create a surface and subtract the slot from it?
what are you drawing?
the bottom of a cylinder. the "slot" is flat and the 'circle' is a constant 8 degree slope which causes the non-coplaner part. which rules out a loft or extrude, etc.. I'll try your suggestion.
thanks!
you can make a disc(solid) and make your slot, then rotate your disk 8degrees. Do you need to end up with a solid model? or are you just going to make a surface model?
actually, it slopes toward the center 8 degrees (consistantly) which makes it a very odd shape. Would prefer to make it a solid but don't know how to accomplish that. I managed to make it a surface which will suffice I guess.
