photoview 360 rendering issues
I am using solidworks 2011 and when creating a preview of the final render of a scene set up looking through a camera i am faced with a preview window which looks as if it has took a render of a wall and the window is blank? anybody come across this problem before and know what it may be?
Thanks
Are you using a standard scene or have you setup your own using lights? If you have setup your own scene with your own lights you have to be sure and check the box(on in photoview) because the lights won't automatically be on. If you can give me a bit more info i can help you out.
I have published a bunch of videos on rendering basics and setting up your own scene on http://www.mymlcservices.com
http://www.mymlcservices.com/index.php?option=com_hwdvideoshare&task=displayresults&Itemid=306&category_id=0&pattern=render&rpp=0&sort=0&ep=&ex=
I am pretty sure i did a few more that didnt show up in that search.
