HI,
I have a problem like
i am inserting a block which consist of dimensions of some style--say height of 2
but when i insert my block i want the block to be inserted in such a way that
so when i scale my block 2 times the height changes to 4 but i need it to change to 10
i used dimscale to increase the dimension but it was not getting updated when inserted
(defun C:nm()
(setq bp (getpoint "Pick a Point on Screen"))
(setq sc (getreal "Enter the Scale Required"))
(setq th (getreal "Enter the Text Height"))
(command "DIMSCALE" th)
(command "insert" "nameplate" bp sc sc 0 )
inputs are point ---picked
scale x,y,z---2
text height= dimscale---10
Can some one help me how to do this i have also attached a drawing file in reference to it
Thank you in advance
raj
Look into Annotative Dimstyles
For example
Insert this file on your drawing
Click on Annotation tab (lower right of your menu)
1:10
nameplate.dwg
Edited by pBe
i was not able to understand what u asked me to do
i want to change the dimheight to the style of dimension as i also have other part drawing in the same sheet so if i change as a globally the whole drawing changes
but in my drawing sheet all the other dimensions will have same properties
i tried out the way u asked me to do it worked out
can u tell me how did u do Annotative Dimstyles i was looking for it but .....
Please can u help me out with this
