Hi,
How to prevent the Xref layer name from prefix of Xref dwg name?
For example If I have been using one layer name as BORDER in Master Dwg.
Now I going to use Master dwg As a External Reference, thereafter
The Above specified Layer name are coming as Master$0$BORDER, while i am using the Master Dwg As a Xref Dwg of my another dwg.
Actually I want to remove highlighted text from layer name?
Your concern must be appreciated.
Thanks in advance.
Please check if solution in this thread is useful for you.
Regards,
Mircea
RRS1987, that is not possible because it is possible to have a layer with the same name but different properties in both files.
