pvd Posted November 3, 2011 Posted November 3, 2011 Hi all, I'm working on a new computer - 64bit instead of 32bit + 6GB Ram instead of 2GB - yeah I'm happy woohoow:shock: but still I think my autocad doesn't work much faster. For example scrolling in paperspace with more than 5 viewports doesn't go fluently at all. Is there any setting I have to put so autocad can use more RAM or any other suggestions? thanks in advance! Quote
rkent Posted November 3, 2011 Posted November 3, 2011 Hi all, I'm working on a new computer - 64bit instead of 32bit + 6GB Ram instead of 2GB - yeah I'm happy woohoow:shock: but still I think my autocad doesn't work much faster. For example scrolling in paperspace with more than 5 viewports doesn't go fluently at all. Is there any setting I have to put so autocad can use more RAM or any other suggestions? thanks in advance! The first things to take care of. Download and install SP1 for AutoCAD. In AutoCAD turn hardware acceleration on. In Win7, turn off aero stuff (at least as a test) Make sure to download the latest driver for your gpu. Sometimes going back a driver or two works as well. Go into the settings in Win7 and adjust the virtual memory. - System and Security, System, Advanced System Settings, System Properties Advanced tab, Performance…settings, advanced tab, virtual memory…change, Initial size = 3X ram (3GB ram = 9GB paging file size), maximum size = 4X ram. Go larger if you have the hard drive space. Also see attached for other ideas, things to try. SPEED UP AUTOCAD 09-20-2011.pdf Quote
rkmcswain Posted November 3, 2011 Posted November 3, 2011 Hi all, I'm working on a new computer - 64bit instead of 32bit + 6GB Ram instead of 2GB ......but still I think my autocad doesn't work much faster. For example scrolling in paperspace with more than 5 viewports doesn't go fluently at all. What video card do you have? ....plus the other stuff that rkent said.... Quote
rkmcswain Posted November 3, 2011 Posted November 3, 2011 Also see attached for other ideas, things to try. Wow, 138 things to do. I didn't look in detail, but I wonder what % of those are "turn off so and so setting"... There needs to be a "Safe mode" way to run AutoCAD which disables all but the essentials.... At least it might help people ID whether or not it's software settings or under-performing hardware Quote
pvd Posted November 3, 2011 Author Posted November 3, 2011 waw rkent, that's a bunge of tips. Thanks already! about my graphics card, it's ATI FirePro V4800 (FireGL) thanks guys, I will let you know if things work! Quote
ReMark Posted November 3, 2011 Posted November 3, 2011 138 things one can do to get AutoCAD to run faster. Not bad. It takes 10 times that number of things to get Windows to work at all! Quote
betazero Posted September 24, 2014 Posted September 24, 2014 Add this to your acad.lsp file or create an empty txt file named acad.lsp and put it where your acad.exe file is. It helps with many different things including speeding up auto cad. (COMMAND "viewres" "y" "500" "sortents" "20" "treedepth" "-2520" "SAVEFIDELITY" "0" "ISAVEPERCENT" "0" "ELEV" "0" "0" "OSNAPZ" "1" "SHOWLAYERUSAGE" "0" "VPLAYEROVERRIDESMODE" "0" "LAYISO" "S" "OFF" "OFF" "" "layoff" "s" "v" "v" "" "whipthread" "3" "PREVIEWEFFECT" "0" "REPORTERROR" "0" "MAXACTVP" "64" "menuecho" "0" "viewres" "Y" "1000" "REGENAUTO" "ON" "trim" "" "e" "n" "" "UCSFOLLOW" "0" "COORDS" "2" "-SCALELISTEDIT" "R" "Y" "E" "CENTERMT" "1" "LAYEREVAL" "0" "LAYERNOTIFY" "0" "VTENABLE" "0" "HPDRAWORDER" "1" "HPORIGINMODE" "1" "DRAWORDERCTL" "3" "ATTIPE" "1" "ucsicon" "OFF") Quote
