programming a C# app to interface with AutoCAD
Hello,
I have absolutely no idea where this topic goes so I'm putting here. Hope that's OK.
I am beginning a project in which I am to program an application in C# that will read a dxf file and then reproduce it in AutoCAD automatically. This means that the application will have to communicate with AutoCAD and issue commands to it directly (like draw line, create face, build new layer, etc.).
Does anyone know how this can be done? How do I interface with AutoCAD from a C# application?
You can write C code for autocad just need the correct library's to be linked and can construct objects lines etc there are examples in the autocad 2011\sample\API\COM\csharp code.
I dont understand why if you have a DXf why not just open it. ?
Moderator maybe move to .net arx forum
Thanks Bigal, but I have the 2008 version. I can go so far as C:\Program Files\AutoCAD 2008\Sample. From there, I see ActiveX, Database Connectivity, DesignCenter, Dynamic Blocks, Mechanical Sample, Sheet Sets, and VBA. I didn't see any C# code samples under any of those.
Good question! I didn't invent the project, I'm just working on it.
