Autosave with Multiple Drawings open in AutCAD 2012 Query
Hi,
If I have multiple drawings open in AutoCAD 2012 does the autosave function only apply to the current drawing open or does it apply to all drawings ?
Cheers
If you tile the drawings so that you can see the command area of one drawing while another is current, you will eventually see it autosave. Or you could open two drawings, make a simple change in the first, go to the second, and later check the first drawing.
Welcome to the forum.
I think only in current drawing..
