How do you create text inside a circle so it bends with it, like the lettering on a coin. I did it using one letter, then using the rotate command to arrange the text but that seems to take ages, so is there a better way to do this? any help will be appreciated
There should be something called "ar Aligned text" in your express tools pulldown...see if that works
There should be something called "ar Aligned text" in your express tools pulldown...see if that works.
Express tools, aligned test, should do the trick. 8)
thankyou, sorry i'v been away for a while, but now i'm back let the good times roll :D :D :D
