Organizing shortcut keys on SU
I now understand why shortcut keys on using sketchUP should be properly organized and remembered... it would really make ur work faster if you have an assigned shortcut keys for each commands that u can easily memorized...
Not sure if there is a question in there somewhere, but I have moved your thread to a more appropriate area of the forum. The Sketchup section.
yes sure, I just want to know if somebody is doing same as me...making personal shortcuts.. I am new to sketchup rendering using vray..
  • 4 weeks later...
I use keyboard shortcuts for my most used commands (line, select, move, measure, etc...).
I started doing this along time ago when autodesk started changing the shortcut key strokes for commands used on a routine basis, such as SA for saveas, but now, 15 some odd years later i regret this because now i have to go and modify my crap everytime i do a new install, not that big a deal really but i've been using them for so long so consistantly that they are instinct, now I try modifying as little as possible in an attempt to adapt to what ever autodesks sillyness throws at me in such regards. If that all makes sense ......
  • 4 months later...
i did add shortcuts on SU but now i'm running out of keys in my keyboard hehehehe
