jverre Posted November 12, 2011 Posted November 12, 2011 I'm working at the moment on a project and for it I need to take into consideration the froction between a pendulum and oil (the pendulum will be in oil). I'm using meca3D to simulate the oscillation of the pendulum but I don't know how to create a force that would be proportionnal to the speed of the pendulum Thanks very much for your help (I hope i have explained my problem clearly=)) photo1.pdf Quote
shift1313 Posted November 14, 2011 Posted November 14, 2011 Sorry, ive never used meca3d. The best thing i could suggest is doing a fluid simulation in SW. You can simulate the motion of the pendulum then add a fluid. Instead of using air or water, you use your oil. Do you have any idea of the friction? Quote
jverre Posted November 14, 2011 Author Posted November 14, 2011 Thing is I don't think i have access to the fluid simulation =( All I found was a little flow simulation which enabled me to generate a flow of liquid or air from one end to another=( Is there an add one I need to download?? thanks very much for you help Quote
shift1313 Posted November 15, 2011 Posted November 15, 2011 it sounds like you have the premium seat of solidworks but no flow simulation. http://www.solidworks.com/sw/products/10201_ENU_HTML.htm Quote
jverre Posted November 20, 2011 Author Posted November 20, 2011 I've managed to get a hold of sdk flow simulation but it looks quite difficult to use =( I'll have a look at it and if there is something i can't figure out I'll post another message. Thanks very much for all your help =) Quote
jverre Posted December 3, 2011 Author Posted December 3, 2011 I have finally had the time to try and use flow simulation, but I can't seem to use it properly. I have put my pendulum in a closed box put I don't know how to make it rotate freely after i have put it at an angle. Do I need to do a simulation first and then add the oil? I'm a bit lost =( Thanks very much for you're help =) Quote
shift1313 Posted December 4, 2011 Posted December 4, 2011 in the simulation you should be able to add gravity(little apple icon if i remember right). Without that no motion will happen without some sort of force added. Quote
