Gearz Drums Posted November 13, 2011 Posted November 13, 2011 New to the program but followed the instructions....IF I follow them to the letter, an *IGES file is created but it is only a 1 KB File of no use (an example *DXF File is 27 MB). I am trying this to see if Autocad is the solution I need to turn all my 3D files into IGES and STL. Does anyone know what basic blunder I am making? Many thanks Quote
JD Mather Posted November 13, 2011 Posted November 13, 2011 Are you 3D models solids (run List)? Are you trying to Export as IGES solids or as IGES surfaces? Create a 1x1x1 cube. Export the IGES. Hit F2 Hit Alt Print Screen. Open MS Paint. Ctrl V to paste the image. Save and attach the F2 image here and attach the original dwg and IGES file here. What problem are you having with stl? Are you aware that free Inventor Fusion will also convert files? ( I have to check on *.stl) Why do you want IGES? Most people today use STEP rather than IGES. Quote
Gearz Drums Posted November 13, 2011 Author Posted November 13, 2011 Are you 3D models solids (run List)? They Aare *DXF solid models. Are you trying to Export as IGES solids or as IGES surfaces? There isn't an option between the two during export,so I would think the solid I select for export should export to solid. Are you aware that free Inventor Fusion will also convert files? ( I have to check on *.stl) Inventor came with the Demo and it doesn't fare any better. Why do you want IGES? Most people today use STEP rather than IGES. Well, some places do good CNC work but just aren't up with the times in software - and I need to get a variety of quotes, so I don't want to exclude those old timers. I will try the experiment you suggested as soon as possible and follow up post. Thanks, Mark Quote
JD Mather Posted November 13, 2011 Posted November 13, 2011 Also - check that your parts are close to the origin 0,0,0 How big are they (geometry bounding box - not file size)? Quote
