Problem importing from Unity Pro
Hi,
Im having a problem using the import from Unity Pro utility where after I select the .xhw and .xsy files I get an error as follows:
The X:\Filename.xsy I/O variable file contains I/O addresses not found in the X:\Filename.xhw hardware file. Do you want to continue this command?
After clicking Yes to continue, my input and output cards are listed but there are no Address's or Descriptions.
If I tick the Show only I/O modules box the modules in the tree disappear.
The .xls spreadsheet that is then generated only contains the part numbers in the CODE column, values of 0 in the B column and values (P) (P) then 0 through 5 in the S column.
Also there is a separate issue of modules from Unity Pro data coming across with no spaces in the part number eg BMXDDI1602 where the part numbers in AutoCad Elec have spaces and therefore can't be found unless spaces are added eg BMX DDI 1602.
If anyone can help me out it would be much appreciated.
Thanks!!
