How do I set the drawing units from the default to meters (or any other of the available units)?
I couldnt find the information I was looking for on the Help menu.
If you want to see my code there is another thread titled VBA basics; created by me.
Look for LUNITS, MEASUREINIT system variables and SetVariable method.
Sorry, I'm a total noob at the moment. This is my first week programming and I'm teaching myself in between workload tasks.
But arent the commands you mentioned, for AutoLISP?
If i were looking for the quickest way to do something then you would be spot on. But at the moment I am just trying to familiarise myself as much as possible with VBA until I get some books and official training.
thanks.
The following code will ask the user to input an integer to set the variable INSUNITS; and then the code will set INSUNITSDEFSOURCE and INSUNITSDEFTARGET variables to the same integer value as what was inputted.
Option Explicit
Public Sub Example_SetVariable()
   Dim retVal As String
   Dim SysvarName As String
   Dim sysVarData As Variant
   Dim DataType As Integer
   ' Set INSUNITS system variable (data type Integer) to 6. NOTE that
   ' you need to declare a variable as the data type of system variable,
   ' assign data to that variable and then make it variant type
   retVal = ThisDrawing.Utility.GetString _
            (1, vbCrLf & "Enter the Value of InsUnits (This will also change InsUnitsDefSource & InsUnitsDefTarget to the same Value): ")
   Dim intData As Integer
   SysvarName = "INSUNITS"
   intData = retVal
   sysVarData = intData    ' Integer data
   ThisDrawing.SetVariable SysvarName, sysVarData
   ' Check the variable using GetVariable
   sysVarData = ThisDrawing.GetVariable(SysvarName)
   MsgBox SysvarName & " = " & sysVarData, , "SetVariable Example"
   SysvarName = "INSUNITSDEFSOURCE"
   SysvarName = "INSUNITSDEFTARGET"
End Sub
Not sure if this is what you are after; but it expands a little on what Asmi commented upon.
For example:
ThisDrawing.SetVariable "LUNITS", 3
Set LUNITS system variable to 3 (Engineering units).
For example:
Thanks I thought you were giving me lisp commands but my inexperience told.
Again, I'll try these when I get to work on Monday and thankyou,
Any ideas which books would be best for me to learn VBA.
If im honest, I dont really understand when I set As variant, As string etc.Ok, i know string is text etc but I'd love a clear definition of each so I am not assuming etc.
Any ideas where I can best find the explanations I need?
Then I can come back and give you guys even more advanced questions :)
For example:
I did try this but when I type UNITS its always set as millimeters.
Look for INSUNITS variable.
Thanks, I finally got there. I just need to read what you guys are saying two or three times before it sinks in sometimes. :)
