hatch error....
hi
i have problem with hatch,if i delete any lines from related hatch protion object area, my all related hatch object erased.pls guide me how to solve problem.
thanks
venki
AutoCAD 2006? Hmmmm....not entirely sure but check to see if there is a system variable called HPBOUNDRETAIN. If there is and it is set to "1" change it to "0" and see if that fixes the problem.
That screenshot is from 2010 LT. You might want to update your profile information cadamrao.
hi
can't solve the problem if I use command HPBOUND '0'.pls check again
any one pls urgent!!!!!!
Edited by cadamrao
fyi
Post the drawing. Someone will take a look at it.
problem solve,un-check associative option from hatch dialog
thanks
venki
Glad to hear your problem is solved and thanks for updating us.
