dagby Posted November 21, 2011 Posted November 21, 2011 Hi everyone, I start using Autodesk Inventor 2012 and I have no idea because I always had to use autocad, I'm an engineer work of art and I would like to use it to model 3D bridges and increase my productivity. So if you have good tutorials pdf or videos that will explain step by step inventor, ie the setting, drawing, exit plans I'd be the happiest in the world. thank you Quote
JD Mather Posted November 21, 2011 Posted November 21, 2011 You might start here http://home.pct.edu/~jmather/SkillsUSA%20University.pdf then go through the Help>Learning Tools>Skill Builders and Tutorials purchase a book Banach and Jones to start then http://www.amazon.com/s/ref=nb_sb_noss/186-3492885-9912953?url=search-alias%3Dstripbooks&field-keywords=autodesk+inventor Waguespack Post your files here as you run into trouble. Quote
