Learning Posted November 21, 2011 Share Posted November 21, 2011 Hello all, I am attempting to join two gutters around a 90 degree fascia. Plese tell me how to accomplish this. I am using a 2008 instruction text and the commands are not the same. Quote Link to comment Share on other sites More sharing options...
Tiger Posted November 21, 2011 Share Posted November 21, 2011 You are posting this in the Revit-section but your info says you use Inventor - would you care to clarify what program you are in fact using? Quote Link to comment Share on other sites More sharing options...
Learning Posted November 23, 2011 Author Share Posted November 23, 2011 You are correct I am using Inventor. However I am also using Autodesk Revit Architecture 2010 and Auto CAD 2010. I am a full time student seeking my CAD Drafting degree at State Fair Community College. Next simester I will also be using Solid Works 2012 in addition to the a fore mentioned programs. Quote Link to comment Share on other sites More sharing options...
Tiger Posted November 23, 2011 Share Posted November 23, 2011 So to make it perfectly clear, the question in the original post is in regards to Inventor? Quote Link to comment Share on other sites More sharing options...
Learning Posted November 23, 2011 Author Share Posted November 23, 2011 The question is about Revit Architectural 2010. I expect like many people in the industry I have to use several different programs. That is why I put the Thread under Revit. I do not know how to list multiply programs under my profile. I am sorry if there has been a confusion. Quote Link to comment Share on other sites More sharing options...
Tiger Posted November 24, 2011 Share Posted November 24, 2011 You are perfectly correct that a lot of people use different softwares, and I commend you for learning multiple softwares in one go. It happens quite often though that threads are posted in the wrong forum-section, to avoid confusion and multiple threads, we move threads where they fit the best, that's why I wanted to make it very clear where this question fitted. Good luck in finding your answer - perhaps if you give more info on what commands the book is telling you to use someone can help with what those commands are called now. Quote Link to comment Share on other sites More sharing options...
