platinum home Posted November 21, 2011 Posted November 21, 2011 I want to create a hatch pattern for vertical siding. Never had to create a hatch before so I'm not sure how to do it. Quote
SuperCAD Posted November 21, 2011 Posted November 21, 2011 Vertical siding as in T1-11 grooved paneling or a beaded panel? What kind of spacing are you looking to use? Quote
platinum home Posted November 21, 2011 Author Posted November 21, 2011 the grooved vertical. I want a spacing of 4" Quote
BIGAL Posted November 22, 2011 Posted November 22, 2011 Can you not use one of the Ansi hatches and just change the angle to be vertical and play with scale to get 4" Quote
mihael_b Posted November 22, 2011 Posted November 22, 2011 (edited) try this: Edited November 22, 2011 by Tiger removed link Quote
Tiger Posted November 22, 2011 Posted November 22, 2011 Mihael_B, I removed your link since you pretty much post that link in every post you post. Two things: you can't post links while you have under 10 posts; there are plenty of questions around to answer for you to get your postcount up. But links that do nothing else but promote your website will most often be removed. The tip you where actually referring too can be found here, straight from the original author: Tech Tip by Robert Levy Quote
