wimal Posted November 22, 2011 Posted November 22, 2011 In some drawings "GRAVEL" Hatch pattern cannot insert properly. Outline of gravel has broken to several parts. To stop that what can I do? Please help. Quote
SuperCAD Posted November 22, 2011 Posted November 22, 2011 Try moving the objects that you're adding the hatch pattern to closer to the 0,0,0 point. Quote
CyberAngel Posted November 22, 2011 Posted November 22, 2011 When I see this, often I can fix it by moving the origin point to a position inside the borders of the hatch. If you have several boundaries, try splitting the single hatch into multiple hatches. If you have one boundary, keep moving the origin until you get a good pattern. Quote
invtw Posted May 11, 2012 Posted May 11, 2012 you can use UCS and move it to near hatch boundary then double click on hatch and press ok key! Quote
wimal Posted May 12, 2012 Author Posted May 12, 2012 you can use UCS and move it to near hatch boundary then double click on hatch and press ok key! Thanks for the new information. Quote
