Does viewres command works only for the layout in which it was applied like pagesetup manager does?
How it is related to the regen and redraw?
The VIEWRES command predates the LAYOUT feature by years.
Why are you inquiring about VIEWRES?
I needed to use the deviation that AutoCAD does for drawing the curves and it uses the VIEWRES system variable.
I am unaware of the VIEWRES functionality and hence I am trying to get some learning about VIEWRES.
