How to load Plug-ins
Hi Guys/Gals,
I do have a query. I have DL a free plugins. How do I load it in 3DSMax 2012 so I can make it work.
As per instruct I just need to go to MODIFIER and look for the name but, I can't seem to find it there.
plugins - Hot4max
Did you follow the installation instructions in the "README" file that's included in the zip?
Did you have Max open when you were installing the dll and dlm files into the Max directory? If so, you will need to close Max and then re-open it.
If you can't get it to work, per the instructions, then you should probably contact the author.
